Hardware details
Pinout
NULA Max RP2350 pinout
NULA Max RP2350 Pinout Diagram
Click here for a high-resolution version of the pinout.
Pin Details
Pin MarkingTypeDescription
3V3PowerRegulated 3.3 V output from onboard regulator.
VCCPowerMain power input (5 V via USB-C or external 5 V supply).
VBATPowerJST battery connector input for 3.7 V Li-Ion/Li-Poly cells.
GNDGroundCommon ground reference.
RESETControlActive-low reset input.
IO0 - IO47GPIOGeneral-purpose I/O pins with peripheral support (PWM, SPI, I²C, UART, etc.).
The front side of the board, which features the female connectors on solder pads, exposes all GPIO pins, power rails, and control interfaces. This view is typically used when soldering or connecting to the top of the board.
The back side markings describe the header pin holes. Only a few pins differ between the two sides, and these are clearly marked in the pinout diagram.
Qwiic / easyC Connector
Qwiic/easyC connector
The NULA Max RP2350 includes a Qwiic/easyC connector for plug-and-play I²C peripherals.
This allows fast prototyping with sensors, displays, and other modules without soldering.
Learn more about Qwiic hardware compatibility and connector pinout.
Power Supply and Battery
  • USB-C port used for programming and power input (5 V).
  • VBAT (JST connector) supports 3.7 V Li-Ion or Li-Poly batteries.
  • Integrated Li-Ion charging circuit with automatic charge/discharge management.
  • VSYS internally regulated to 3.3 V for logic and peripherals.
When using a battery, the onboard charging circuit handles charging automatically via USB.
For 5 V supply, always power the board through the USB-C port.
Jumper Details
This board includes five hardware jumpers for power management and peripheral configuration.
Loading carousel...
JumperDefault StateFunction
JP1NC (Normally Closed)Disconnects Power LED to reduce standby current.
JP2NC (Normally Closed)Enables MicroSD chip select line.
JP3NC (Normally Closed)Connects GPIO4 to the MicroSD card power enable line.
JP4NO (Normally Open)Keeps the microSD card powered at all times when closed.
JP5NC (Normally Closed)Enables Qwiic I²C interface.
Dimensions
  • Board size: 69 × 58.5 mm (2.72 × 2.30 inch)
  • Mounting: Breadboard compatible
  • Header Pin Holes: 1.5 mm
Soldered boards are LEGO compatible! 🧱
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
