Simple Fire Sensor - How it works
Both the regular and Qwiic versions of the sensor use a phototransistor to detect infrared radiation. The difference between them is the onboard IC, which processes the provided data. The regular version uses a simple LM393 voltage comparator by Texas Instruments, while the Qwiic version uses an ATTiny404 MCU to process the data and implement I2C communication.
Datasheet
For an in-depth look at technical specifications, refer to the official ATTiny404 / LM393 Datasheet:
ATTiny404 Datasheet
Detailed technical documentation for the LM393 Voltage Comparator.
LM393 Datasheet
Detailed technical documentation for the ATTiny404 microcontroller.
How the sensor works
The fire sensor operates on the principle of detecting infrared radiation emitted by an open flame. To detect that radiation, the sensor utilizes a photodiode (IR receiver) that changes its resistance, which in turn alters the internal voltage. The sensor includes an IC to provide additional functionality and simplify its operation.
I2C communication - Qwiic
Qwiic versions of the product use onboard ATTINY404 MCU to implement I2C communication. Breakout board operates with a default I2C address of 0x30 but can be changed with onboard switches,to change breakout board's address, check the Address selection. When detected, ATTINY404 recives data from sensor and passes it to the main MCU using I2C data line. To check in detail how to ATTINY404 is preprogrammed, check firmware github page.
