Slider Potentiometer - Hardware details
Pinout
Pin details
| Pin Name | Description | Notes |
| OUTA | Analog Output A | Outputs analog signal (side A). |
| VCCA | Power Supply A | Connect to 5V for side A. |
| GND | Ground | Common ground for both sides. |
| OUTB | Analog Output B | Outputs analog signal (side B). |
| VCCB | Power Supply B | Connect to 5V for side B. |
Qwiic (formerly easyC)
Pin details for Qwiic version
For the Qwiic version, connection is achieved with the Qwiic connector.
Address selection for Qwiic version
The board contains hardware address switches. See below for instructions on how to change the breakout board's address.
Address Table
| Address | SW3 | SW2 | SW1 |
| 0x30 | 0 | 0 | 0 |
| 0x31 | 0 | 0 | 1 |
| 0x32 | 0 | 1 | 0 |
| 0x33 | 0 | 1 | 1 |
| 0x34 | 1 | 0 | 0 |
| 0x35 | 1 | 0 | 1 |
| 0x36 | 1 | 1 | 0 |
| 0x37 | 1 | 1 | 1 |
Dimensions
- Board Dimensions: 86 × 22 mm (3.39 × 0.9 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO-compatible! 🧱
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
- Safety Instructions – Safety guidelines and precautions in English and German.
