Slider Potentiometer - Overview
Slider Potentiometer Breakout
The Slider Potentiometer Breakout is a linear potentiometer with a resistance of 10kΩ, ideal for projects requiring manual resistance control. It is commonly used in audio equipment and other applications where linear adjustment is necessary.
Slider potentiometer
333130
Slider potentiometer with easyC
333131
Key Features
  • Type: Linear potentiometer for precise resistance adjustment.
  • Resistance: 10kΩ, ideal for a wide range of applications.
  • Connectivity: 2
  • Qwiic (easyC ecosystem) for plug-and-play functionality—no soldering required (for the Qwiic version).
  • Dimensions: Compact design measuring 86 × 22 mm.
  • Applications: Suitable for audio equipment, robotics, and other projects requiring manual control.
  • Compatibility: Designed for seamless integration with Arduino and other microcontrollers.
You may also need
Qwiic cable
Qwiic cable
