Ssd1306 - Drawing shapes
This page contains some examples of drawing and rendering shapes onto the OLED display.
Rectangles
Rectangles can be drawn onto the screen using the drawRect() function by specifying the upper left x and y coordinates, as well as the height and width of the rectangle. In this example, we draw progressively smaller rectangles until we reach the center:
delay(1000);
// Clear the last image shown on screen
display.clearDisplay();
//Initialize the upper left coordinates of the rectangle
int16_t x=0,y=0;
//Stop the loop only when either the x or y coordinate is over the middle of the screen
while(x<display.width()/2 && y<display.height()/2)
//Make the width and height smaller as we get to the center
int16_t rect_width=display.width()-(x*2);
int16_t rect_height=display.height()-(y*2);
//Draw the rectangle
display.drawRect(x,y,rect_width,rect_height,SSD1306_WHITE);
//Display each rectangle as we put it into the buffer
display.display();
delay(500);
//Create a gap of 1 pixel between each rectangle
x+=2;
y+=2;
display.drawRect(uint16_t x0, uint16_t y0, uint16_t w, uint16_t h, uint16_t color)
Puts a rectangle into the buffer, ready to be drawn
Returns value: None
| Type | Name | Description |
uint16_t | x0 | Upper left x coordinate of the rectangle |
uint16_t | y0 | Upper y coordinate of the rectangle |
uint16_t | w | Width of the rectangle |
uint16_t | h | Height of the rectangle |
uint16_t | color | Color of the rectangle |
Circles
Circles can be drawn onto the screen using the drawCircle() function by specifying the x and y coordinates of the circle's center, its radius, and its color. In this example, we draw 10-pixel-wide circles until they reach the end of the screen:
delay(1000);
int16_t x,y;
//Iterate the y coordinates every time we fill a row with circles
for(y=4;y<display.height();y+=8)
for(x=4;x<display.width();x+=8)
//Draw a circle at current x and y with a radius of 4 pixels
display.drawCircle(x, y, 4, SSD1306_WHITE);
//Display the circle
display.display();
delay(300);
display.drawCircle(uint16_t x0, uint16_t y0, uint16_t r, uint16_t color)
Puts a circle into the buffer, ready to be drawn
Returns value: None
uint16_t | x0 | x coordinate of centre of circle |
uint16_t | y0 | y coordinate of centre of circle |
uint16_t | r | Radius of circle |
uint16_t | color | Color of the circle |
