2.4" TFT LCD Breakout with Touch - getting started
This page provides the essential information for getting started, including board and library installation.
Arduino library
Soldered TFT LCD Arduino Library
TFT LCD Arduino library by Soldered
First-time Arduino user? For a detailed tutorial on how to get started with Arduino, see this section of our docs:
Getting started with Arduino
How to Connect the TFT LCD Breakout 2.4"
The TFT LCD Breakout 2.4" with Touch display can be connected to any ESP32 or other microcontroller with SPI support. It uses standard SPI for display data and an additional SPI chip select pin for touch input. Below is a general guide for wiring and initializing the display and touchscreen using user-defined GPIO pins.
Pin Connection Table
| TFT LCD Pin | Function | Microcontroller Role / Pin Type | Notes |
| VCC | Power | 3.3V or 5V power output | Powers the display and backlight. |
| GND | Ground | GND | Common ground connection. |
| CLK | SPI Clock | SPI Clock (SCK) | Shared with other SPI devices if needed. |
| DI | SPI Data (MOSI) | SPI MOSI | Sends data to the display. |
| D0 | SPI Data (MISO) | SPI MISO | Required for touchscreen functionality. |
| CSL | TFT Chip Select | Any free digital GPIO | Used in display constructor as TFT_CSL. |
| DC | Data/Command Select | Any free digital GPIO | Used in display constructor as TFT_DC. |
| RST | Reset (optional) | Any GPIO or -1 | Set to -1 in code if not connected. Optional hardware reset. |
| CST | Touch Chip Select | Any free digital GPIO | Used in touchscreen constructor: TFTTouch ts(<pin>). |
| BL | Backlight | VCC or PWM-capable GPIO | Connect to 3.3V or 5V for always-on, or a PWM pin for dimming. |
Example Code
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "TFT-LCD-Breakout-2.4-With-Touch-SOLDERED.h"
// User-defined pins
#define TFT_CSL 25 // TFT Chip Select
#define TFT_DC 33 // TFT Data/Command
#define TFT_RST -1 // Use -1 if RST not connected
#define TOUCH_CS 5 // Touchscreen Chip Select
// Use VSPI on ESP32
SPIClass vspi(VSPI);
// Initialize display and touchscreen
TFTDisplay tft(TFT_CSL, TFT_DC, TFT_RST);
TFTTouch ts(TOUCH_CS);
// Initialize VSPI with SCK, MISO, MOSI
vspi.begin(18, 19, 23);
// Optionally set SPI speed (e.g., 40 MHz)
vspi.setFrequency(40000000);
// Begin display and touch
tft.begin();
ts.begin();
// Optional touchscreen calibration
ts.calibrate(540, 1000, 34, 460); // Adjust values as needed
// Clear screen
tft.fillScreen(ILI9341_BLACK);
// Your code here: draw shapes, detect touch, etc.
Tips
- The D0/MISO pin must be connected for the touchscreen to function properly.
- Use
vspi.setFrequency(40000000);to manually adjust SPI speed if necessary. - Ensure your board has stable power—some displays may require up to 100mA during full backlight and drawing operations.
