VL53L1X ToF Laser Distance Sensor - Measuring distance example (Arduino)
This page provides simple continuous distance readings from the sensor, with dynamic control of LED brightness based on measured distance.
Important: Before starting to work with the sensor, the orange protective sticker needs to be peeled off for the laser to emit and be detected properly!
VL53L1X ToF Laser Distance Sensor remove sticker
Remove the protective orange sticker before use
Initialization
To use the VL53L1X sensor, include the required library, create the sensor object and initialize the sensor in setup() function along with specifying desired DistanceMode.
// Include the library
#include "VL53L1X-SOLDERED.h"
#define LED_PIN 15
VL53_L1X sensor;
Serial.println("Serial Initialised");
sensor.setTimeout(500);
sensor.begin();
// You can change these settings to adjust the performance of the sensor, but
// the minimum timing budget is 20 ms for short distance mode and 33 ms for
// medium and long distance modes.
sensor.setDistanceMode(VL53L1X::Short); // We use SHORT distance mode for LED visualization purposes
sensor.setMeasurementTimingBudget(50000); // We use 50000 us (50 ms) for a measurement.
// Start continuous readings at a rate of one measurement every 50 ms (the
// inter-measurement period). This period should be at least as long as the
// timing budget.
sensor.startContinuous(50);
sensor.begin()
Initializes the VL53L1X sensor, setting up communication over I2C.
Returns value: None
sensor.setTimeout()
Set a timeout period in milliseconds.
Returns value: None
uint16_ttimeoutSets a timeout period in milliseconds after which read operations will abort if the sensor is not ready. A value of 0 disables the timeout.
sensor.setDistanceMode()
Sets the distance mode of the sensor (see table below).
Returns type: bool
Returns value: Indicates whether the requested mode was valid.
DistanceModemodeSets the distance mode of the sensor.
The VL53L1X has three distance modes: short, medium and long.
Long distance mode allows the longest possible ranging distance of 4 m to be reached. However, this maximum ranging distance is impacted by ambient light. Short distance mode is more immune to ambient light, but its maximum ranging distance is typically limited to 1.3m
Distance ModeEnumMax. distance under strong ambient light (cm)Max. distance in the dark (cm)
ShortVL53L1X::Short135136
MediumVL53L1X::Medium76290
LongVL53L1X::Long73360
sensor.setMeasurementTimingBudget()
Time allowed for one range measurement; a longer timing budget allows for more accurate measurements.
Returns type: bool
Returns value: Indicates whether the requested budget was valid.
uint32_tbudget_usSets the measurement timing budget to the given value in microseconds.
Measuring distance
In the loop function sensor.read() is called to get object distance in millimeters.
// Get distance reading in 'mm'
int distance = sensor.read();
Serial.println(distance);
// Map distance (0 - 2260) to PWM (0 - 255)
// Max distance in short mode ~ 2260mm
int pwmValue = map(distance, 0, 2260, 0, 255);
// Output PWM to LED
analogWrite(LED_PIN, pwmValue);
if (sensor.timeoutOccurred()) // Check if sensor has been measuring longer than timeout period
Serial.print(" TIMEOUT");
sensor.read()
Returns a range reading and updates the ranging data struct with details about the last measurement.
Returns type: int
Returns value: Returns distance from objects in millimeters.
booleanblockingOptional argument, if True: wait until data from a new measurement is available before returning.
Full example in Arduino library
ReadDistanceContinous.ino
Full sketch example of continous distance reading
