VL53L1X ToF Laser Distance Sensor - How it works
The VL53L1X ToF Laser Distance Sensor is a high-performance Time-of-Flight (ToF) laser-ranging sensor by STMicroelectronics.
Important note
Datasheet
For an in-depth look at technical specifications, have a look at the datasheet:
VL53L1X ToF Laser Distance Sensor Datasheet
View full VL53L1X ToF Laser Distance Sensor datasheet
How the sensor works
The VL53L1X is an advanced and compact Time-of-Flight (ToF) distance sensor, meaning it measures how long the light has taken to bounce back to sensor unlike IR sensors that measure amount of light reflected back to them. It uses a very narrow light source, which makes it very precise at determining the distance of the surface in front of it.
Measurement process
1. Laser Pulse emmission
- The sensor emits a quick pulse of invisible infrared light using a tiny laser (VCSEL - vertical-cavity surface-emitting laser) at 940nm wavelength.
2. Bounce Back
- The emitted light pulse travles through the air, hits an object, and reflects back to the onboard sensor.
3. Single Photon Detection
- The reflected light is captured by a very sensitive array of detectors called SPADS (Single Photon Avalanche Diodes), capable of detecting single photons of light.
4. Time measurement
- The sensor's built-in microcontroller precisely calculates how long it took for the light to go out and reflect back. Since the speed of light is constant, this time can be used to calculate the exact distance to the object.
Additional features
- Programmable region of interest (ROI)
- ROI size and position are programmable.
- Choose custom FoV from 4x4 SPADs (min.) up to 16x16 SPADs (full FoV)
- Shutdown Pin
- SHTD pin allows to put the sensor into hardware standby mode
- GPIO Interrupt
- Digital output that acts as an interrupt line from the sensor to your microcontroller
- It can signal new distance measurement, a threshold condition has been met
Qwiic I²C communication
This product uses I²C communication. The breakout board operates with a default I²C address of 0x29.
