BMP388 Pressure & Temperature Sensor - Hardware details
Pinout
Pin details
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| SDA | Data | I2C data line for communication. |
| SCL | Clock | I2C clock line for communication. |
Qwiic (formerly easyC)
Dimensions
- Board Dimensions: 38 x 22mm (1.5 x 0.9 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
Jumper Details
This board contains hardware jumpers. See below for their locations and functions:
| JP1 | Normally closed | Connects SDA/SCL pull-up resistors to 5V for I2C communication. |
| JP2 | Normally open | Used to change the device address. When shorted to GND, the address is 0x76, 0x77 when connected to VCC. |
| JP3 | Normally closed | Connects SDA/SCL pull-up resistors to 3.3V for I2C communication. |
| JP4 | Normally open | When connected, the voltage regulator is powered by 5V |
| JP5 | Normally closed | Enables the voltage regulator |
Hardware repository
Pressure & Temperature Sensor BMP388 Hardware design
The hardware repository contains everything you need to understand, modify, or manufacture the board. The different output folders are versioned. You can determine your board version by checking the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
