Electrochemical Gas Sensors – Getting started
Acknowledgement
The Soldered Electrochemical Gas Sensor Breakout Arduino library is based on the ADS1X15 library by RobTillaart and the LMP91000 library by WickedDevice. As such, its source code is licensed under the MIT License. For more details, see the MIT License.
Arduino library
To install the Arduino library, you can download it from the GitHub repository:
Electrochemical Gas Sensor library by Soldered
Getting started with Arduino
Connections
| Qwiic | Qwiic |
If you prefer, you can use I2C pins to manually connect.
