Hall Effect Sensor - Getting started
Arduino library
Hall effect sensor Arduino library
Hall effect sensor Arduino library by Soldered
Getting started with Arduino
Connections (regular version)
IO5 for digital / IO12 for analogOUT
3V3VCC
GNDGND
Digital version can use any digital input pin while analog can use any analog pin input, Check Pinout drawing for your specific board
Connections (Qwiic)
Below is an example Qwiic (I2C) connection diagram for Dasduino CONNECTPLUS. These pins will be used in the examples throughout this documentation. To change the breakout board's address, check the Address selection.
QwiicQwiic
Qwiic versions also contain UPDI headers for preprogramming the onboard ATTINY404 MCU, they are used for debugging purposes only!.
