Hc Sr04 - Getting started
Arduino library
Ultrasonic sensor with easyC Arduino library
Ultrasonic sensor with easyC Arduino library by Soldered
Getting started with Arduino
Connections
QwiicQwiic
UPDI stands for Unified Program and Debug Interface. It is used to program and debug Atmel devices. The Atmel chip on this board is used for the easyC I2C communication only. DO NOT try to use this for sensor communication!
