Stereo I2S Audio Amplifier - Getting started
Arduino library
Stereo I2S Audio Amplifier Arduino library
Stereo I2S Audio Amplifier library by Soldered
This library only works on multi-core chips like ESP32, ESP32-S3 and ESP32-P4. Your board must have PSRAM! It does not work on the ESP32-S2, ESP32-C3 etc.
Getting started with Arduino
Connections
Dasduino CONNECTPLUSI2S Audio Amplifier board
VCCVCC
IO27BCLK
IO25DIN
IO26LRCLK
GNDGND
Connection image
