Arduino - Getting started
Arduino library
Soldered-8x8-MAX7219-LED-Matrix-Arduino-Library
8x8 Led Matrix board by Soldered using MAX7219 chip
First time Arduino user? For a detailed tutorial on how to get started wtih Arduino, see this section of our docs:
Getting started with Arduino
Connections
IO4LOAD
IO18CLK
IO23DIN
VCCVCC
GNDGND
LOAD pin can be any digital IO pin on controller, CLK and DIN pins must be default SPI communication pins(SCK for CLK and MOSI for DIN) if no external library such as Wire.h is used!
Connections for daisy chaining
First BoardNext Board
CLKCLK
LOADLOAD
DINDOUT
VCCVCC
GNDGND
