Ltr 507 - Getting started
Arduino library
LTR-507 Arduino library
Digital Light and Proximity Sensor Arduino library by Soldered
First-time Arduino user? For a detailed tutorial on getting started with Arduino, see this section of our docs:
Getting started with Arduino
A comprehensive and detailed tutorial on how to set up and upload code to an Arduino board for the first time from scratch!
Connections
Dasduino CONNECTPLUSLTR-507
QwiicQwiic
If you prefer, you can use I2C pins to manually connect:
IO21 (Default SDA pin)SDA
IO22 (Default SCL pin)SCL
VCCVCC
GNDGND
3V3VLED
IO25 (any digital pin works)INT
An IR LED must be connected! Ensure proper wiring for the IR LED as shown below for the proximity sensor to work.
LTR-507IR LED
VLEDCATHODE (-)
VCCANODE (+)
Interrupt functionality is not yet implemented.
