Microsd Reader – How it works
The SD card reader's communication is handled by the TXB0104 chip from Texas Instruments.
TXB0104 chip on board
Datasheet
For an in-depth look at the technical specifications, refer to the official TXB0104 Datasheet:
TXB0104 Datasheet
Detailed technical documentation for the TXB0104 chip
How an SD Card reader works
An SD card reader facilitates communication between an SD card and a host device by establishing electrical connections and enabling data transfer through standard protocols. Here’s a breakdown of its operation at the electrical level:
Electrical interface and pin configuration
The micro SD card's SPI interface is implemented using the standard 8-pin micro SD card pinout, with pins corresponding to SPI signals. Here's how the micro SD card pinout relates to the SPI signals:
PinPin NameDescription
1RSVReserved (Not in use)
2CSChip selection for SPI
3DIData input
4VDDPower supply
5SCLKSerial clock for communication
6VSSGround
7DAT0Data output
8RSVReserved (Not in use)
Pinout of an SD card
Power-on & Initialization
Once inserted, the SD card reader:
  1. Applies power (3.3V) to the SD card via the VDD pin.
  2. Performs a voltage check to confirm that the SD card operates within specifications.
  3. Activates the pull-up resistors to stabilize signals.
  4. Initiates the SD protocol.
Read operations
  1. The host sends a read command via the DI pin.
  2. The SD card locates the requested data and transmits it via the DAT0 pin.
  3. Synchronization is ensured by the serial clock.
Write operations
  1. The host sends a write command via the DI pin along with data blocks.
  2. The SD card writes the data to NAND flash memory while sending status responses.
