Pir Sensor - Overview
PIR Movement sensor
The PIR Movement sensor is a device that detects physical movement within its field of vision by sensing changes in infrared radiation. This sensor works on the principle of detecting thermal signals emitted by objects, predominantly warm-blooded creatures like humans. The “passive” in the name refers to the fact that the sensor itself does not emit or radiate any energy for detection. The Qwiic version of this product communicates via I2C on a user-defined address.
PIR Movement sensor
Which products does this documentation cover?
PIR Movement sensor board
333083
PIR Movement sensor board with easyC
333179
Key Features
Standard version:
- Voltage: 2.7-12V
- Delay: 2s
- Sensing range: Angle up to 100 degrees, 3-5 meters
- Dimensions: 38 x 22 mm (1.5 x 0.9 inches)
- Mounting: Four mounting holes for secure attachment
easyC compatible version:
- Voltage: 2.7-12V
- Delay: 2s
- Microcontroller: ATTINY404
- Communication: I2C
You may also need
Qwiic cable
