Rotary Encoder - Overview
Rotary encoder
The Rotary encoder board, also called a shaft encoder, is an electro-mechanical device that converts the angular position or motion of a shaft to analog or digital output signals. This product is a great option for projects that implement linear model to change data value,such as volume control knobs. It features I2C communication with a hardware-defined address of 0x70 and is designed for seamless Qwiic (formerly easyC) connectivity—eliminating the need for soldering.
Rotary encoder board with easyC
Which product is this documetation for?
333188
  • Voltage: 3.3V
  • Rotary encoder PN: EC11E1534408
  • Microcontroller: ATTiny404
  • Signal translation for easy microcontroller interpretation
  • Communication: I2C
  • Mounting: Four mounting holes for secure attachment
  • Dimensions: 38 × 38 mm (1.5 × 1.5 inch)
You may also need
Qwiic cable
Qwiic cable
