Rs 232 - Getting started
Arduino library
To test the Arduino, you can use the SoftwareSerial/HardwareSerial librarys which dont need to be downloaded since they are built into the device. Since the device requires no additional coding, this example is enough to showcase it.
Getting started with Arduino
Connections
Below is an example connection diagram for Dasduino CONNECTPLUS and the RS-232 Transceiver Breakout Board. These pins will be used in the examples throughout this documentation.
Dasduino CONNECTPLUSRS-232 Breakout Board
IO13 (TX) (user choice)DIN1 (TTL Transmit)
IO14 (RX) (user choice)ROUT1 (TTL Receive)
5V5V
GNDGND
If you prefer, you can use a second RS-232 channel for additional communication:
IO27 (TX) (user choice)DIN2 (TTL Transmit)
IO26 (RX) (user choice)ROUT2 (TTL Receive)
5V5V
GNDGND
