Rs 485 - Getting started
Arduino library
To test the RS-485 Transceiver Breakout Board with Arduino, you can use the HardwareSerial library, which is built into the Arduino IDE and does not require additional installation. Since RS-485 communication uses differential signals, this example is sufficient to showcase its functionality.
Getting started with Arduino
Connections
Below is an example connection diagram for Dasduino CONNECTPLUS and the RS-485 Transceiver Breakout Board. These pins will be used in the examples throughout this documentation.
Dasduino CONNECTPLUSRS-485 Breakout Board
IO13 (TX)(*User Choice)D (Driver Input)
IO14 (RX)(*User Choice)R (Receiver Output)
IO12 (DE)DE (Driver Enable)
IO2 (NRE)NRE (Receiver Enable)
5VVCC
GNDGND
ARS-485 Bus Line A
BRS-485 Bus Line B
If your RS-485 breakout board is at one end of the bus, close jumper JP2 to enable the termination resistor. If it’s not at an endpoint, leave JP2 open.
If you prefer, you can use a second RS-485 channel for additional communication:
IO27 (TX)(*User Choice)D (Driver Input)
IO26 (RX)(*User Choice)R (Receiver Output)
IO25 (DE)DE (Driver Enable)
IO24 (NRE)NRE (Receiver Enable)
5VVCC
GNDGND
ARS-485 Bus Line A
BRS-485 Bus Line B
