Simple Light Sensor - Overview
Simple light sensor
The simple light sensor breakout board is a precise sensor that detects the presence and intensity of ambient light. This sensor features a light-dependent resistor (LDR) that detects light. This sensor is also available in a version with I2C communication, with a default address of 0x30, and is designed for seamless Qwiic (formerly easyC) connectivity—eliminating the need for soldering.
Qwiic version of the light sensor board
Qwiic version of the fire sensor board
Regular version of the fire sensor board
Regular version of the light sensor board
Simple light sensor with easyC
333041
Simple light sensor
Simple light sensor
333046
Key Features
  • Regular
    • Operating voltage: 3.3V - 5V
    • Output: analog and digital
    • IC: LM393 comparator
    • Mounting: Two mounting holes
    • Dimensions: 22 x 22 mm (0.9 x 0.9 inch)
  • Qwiic
    • IC: ATTINY404
    • Communication: I2C (You may change the address via the switches on the front of the board)
    • Mounting: Four mounting holes for secure attachment
    • Dimensions: 38 × 22 mm (1.5 × 0.9 inch)
You may also need
Qwiic cable
Qwiic cable
