Slider Potentiometer - Reading Slider Potentiometer
This page contains some simple examples of how to take analog slider measurements using the Slider Potentiometer.
Initialization
To start using the Slider Potentiometer Breakout, you need to connect it to your microcontroller. The potentiometer acts as a voltage divider, and its output can be read through an analog pin on your microcontroller.
Here's how to set it up:
// Define the analog pin connected to the potentiometer
#define SLIDER_PIN 2
// Initialize serial communication for debugging
// Read the analog value from the slider potentiometer
int sliderValue = analogRead(SLIDER_PIN);
// Print the value to the serial monitor
Serial.print("Slider Value: ");
Serial.println(sliderValue);
delay(100); // Add a short delay for stability
Reads the analog voltage output of the slider potentiometer and converts it to a digital value (0–1023 for 5V systems).
Returns value: Returns an integer representing the slider's position as a digital value.
Slider potentiometer readings 1
Serial Monitor output for position 1
Slider potentiometer readings 2
Serial Monitor output for position 2
