Ssd1306 - Getting started
This page provides the essential information for getting started, including board and library installation and wiring the breakout board to your microcontroller.
Acknowledgement
The Soldered OLED Display Arduino library is based on the Adafruit_SSD1306 library by Adafruit. As such, its source code is licensed under the MIT License. For more details, see the MIT License.
Arduino library
To install the Arduino library, you can download it from the GitHub repository:
OLED Display Arduino library by Soldered
Getting started with Arduino
Connections
| Qwiic | Qwiic |
If you prefer, you can use I2C pins to manually connect:
