Apds 9960 - Color Sensor
This page contains simple examples of initialization and color detection using the APDS-9960 sensor.
Color Sensor
In this code snippet, the loop() function continuously checks whether a color reading is available from the APDS-9960 sensor. It uses the colorAvailable() function to wait until the color reading is ready. If the reading is not available, the delay(5) function pauses briefly before checking again.
Once a color reading becomes available, the readColor() function is called to retrieve the red, green, and blue (RGB) color intensities. These values are stored in the variables r, g, and b, respectively.
The RGB values are then printed to the Serial Monitor to display the current color detected by the sensor. A newline is added after each set of color values for readability.
To prevent continuous querying and to control the reading frequency, a delay(1000) function is used to pause for one second before taking another color reading.
// check if a color reading is available
while (!APDS.colorAvailable())
delay(5); // Wait for a color reading to be available
int r, g, b; // Initialize variables for color intensities
// read the color
APDS.readColor(r, g, b);
// print the values
Serial.print("r = ");
Serial.println(r);
Serial.print("g = ");
Serial.println(g);
Serial.print("b = ");
Serial.println(b);
Serial.println();
// wait a bit before reading again
delay(1000);
Enables the color sensor and verifies the sensor's status.
Returns value: An integer: 1 if color data is available, 0 otherwise.
APDS.readColor()
Reads color data (clear, red, green, and blue) from the APDS9960 sensor and stores the values in references.
Returns value: True if the data is successfully read and false if an error occurs, setting the color values to -1 in case of failure.
Open the Serial Monitor at 115200 baud to observe the detected color values.
// Include the library
#include "APDS9960-SOLDERED.h"
// Create an APDS-9960 object
APDS_9960 APDS;
// Setup function, runs once
Serial.begin(115200); // Begin serial communication with the PC
while (!Serial) // Wait until serial becomes active
if (!APDS.begin()) // Begin communication with the sensor
Serial.println("Error initializing APDS-9960 sensor!");
while (1); // Loop forever if the sensor is not available
Serial.println("Sensor initialized.");
// read the color
// print the values
Serial.println(r);
Serial.println(g);
Serial.println(b);
Serial.println();
delay(1000);
ColorSensor.ino
Example file for using the APDS-9960 sensor with easyC/Qwiic/I2C
