Inkplate 10 – Display modes
As mentioned on the previous page, Inkplate 10 has two different display modes: black and white (1-bit) mode and grayscale (3-bit) mode. This page contains more information on both.
Black and white mode
1-bit or black and white mode is the simpler and faster display mode. In this mode, pixels are either black or white. You can use shorthand defines BLACK and WHITE when selecting colors in this mode. For example, to draw and display a single black and a single white pixel:
#include "Inkplate.h"
inkplate.begin();
// Clear the display
inkplate.clearDisplay();
inkplate.display();
// Draw a black pixel at x=100, y=100
inkplate.drawPixel(100,100,BLACK);
// Draw a white pixel at x=200, y=200
inkplate.drawPixel(200,200,WHITE);
inkplate.display(); // Show on the display
Grayscale mode
3-bit or grayscale mode offers the possibility to draw in 8 different levels of brightness, not just black and white. See below for an approximate visualization of black levels as they correspond to their numerical value in code:
Let's draw a couple of rectangles (with a black outline) of different brightness levels:
Inkplate inkplate(INKPLATE_3BIT);
inkplate.begin();
inkplate.display();
// Draw a filled rectangle with a black outline at (100, 100)
inkplate.fillRect(100, 100, 10, 10, 0); // Black fill
inkplate.drawRect(100, 100, 10, 10, 0); // Black outline
// Draw a filled rectangle with a black outline at (200, 200)
inkplate.fillRect(200, 200, 10, 10, 7); // White fill
inkplate.drawRect(200, 200, 10, 10, 0); // Black outline
// Draw a filled rectangle with a black outline at (200, 250)
inkplate.fillRect(200, 250, 10, 10, 3); // Light gray fill
inkplate.drawRect(200, 250, 10, 10, 0); // Black outline
// Draw a filled rectangle with a black outline at (250, 200)
inkplate.fillRect(250, 200, 10, 10, 2); // Dark gray fill
inkplate.drawRect(250, 200, 10, 10, 0); // Black outline
Inkplate10_Black_And_White.ino
Full example using black and white display mode on Inkplate 10.
Inkplate10_Grayscale.ino
Full example using grayscale display mode on Inkplate 10.
