Inkplate 10 – Draw Image from Web
Drawing an image from the web on Inkplate 10 is simple using the draw function, which supports multiple image formats.
Supported formats: JPG, BMP, and PNG.
JPG files without progressive encoding are supported.
If you experience issues displaying an image, try re-saving it with an image editing program. The issue is usually related to the image format.
Drawing an Image from a URL
Let's draw this image of the Eurodom building in Osijek, Croatia on Inkplate 10:
Example Image
Example image by @filipbaotic on Pexels
#include "Inkplate.h"            //Include Inkplate library to the sketch
#include "WiFi.h" //Include library for WiFi
const char ssid[] = "yourssid"; // Your WiFi SSID
const char *password = "yourpassword"; // Your WiFi password
display.print("Connecting to WiFi...");
display.partialUpdate();
// Connect to the WiFi network.
WiFi.mode(WIFI_MODE_STA);
WiFi.begin(ssid, password);
delay(500);
display.print(".");
display.println("\nWiFi OK! Downloading...");
if (!display.drawImage("https://docs.inkplate.com/img/sample_image.jpg", 0, 0, false, false))
// If is something failed (wrong filename or wrong bitmap format), write error message on the screen.
// REMEMBER! You can only use Windows Bitmap file with color depth of 1, 4, 8 or 24 bits with no compression!
display.println("Image open error");
display.display();
display.display();
WiFi.mode(WIFI_OFF);
// Nothing...
inkplate.drawImage()
Function draws image from char path.
Returns value: Returns true if image was successfully drawn, otherwise false.
const char*pathPath and filename of the image. Can be a URL (for web images) or a file path (on the microSD card).
intxX-coordinate of the image's upper-left corner in the framebuffer.
intyY-coordinate of the image's upper-left corner in the framebuffer.
uint8_tditherDithering mode: 0 (disabled), 1 (enabled).
boolinvertIf true, inverts colors.
Full Example
Inkplate10_Image_From_Web.ino
Connect to WiFi and draw an image from the web.
