Obstacle Sensor - Getting started
Arduino library
Soldered-Obstacle-Sensor-Arduino-Library
Library for Qwiic IR Obstacle Sensor board.
Getting started with Arduino
Connections
QwiicQwiic
This board also contains UPDI headers for preprogramming the onboard ATTINY404; they are used only for debugging purposes.
