Rotary Encoder - Getting started
Arduino Library
Rotary encoder with Qwiic Arduino library
Rotary encoder with Qwiic Arduino library by Soldered
First time Arduino user? For a detailed tutorial on how to get started wtih Arduino, see this section of our docs:
Getting started with Arduino
Connections
Below is an example connection diagram for Dasduino CONNECTPLUS. These pins will be used in the examples throughout this documentation. To change circuit boards address, check the Address selection.
| Qwiic | Qwiic |
Qwiic versions also contain UPDI headers for onboard ATTINY404 programing, they are not used for encoder communication!
