Simple Fire Sensor - Getting started
Arduino library
Simple fire sensor Arduino library
Simple fire sensor Arduino library by Soldered
First-time Arduino user? For a detailed tutorial on how to get started with Arduino, see this section of our docs:
Getting started with Arduino
Connections
IO14 (Any ADC pin)A0
IO15 (Any Digital pin)D0
VCC5V
GNDGND
The digital version can use any digital input pin, while the analog version can use any analog input pin. Check the Pinout drawing for your specific board.
Connections (Qwiic)
Below is an example Qwiic (I2C) connection diagram for Dasduino CONNECTPLUS. These pins will be used in the examples throughout this documentation. To change the breakout board's address, check the Address selection.
QwiicQwiic
Qwiic versions also include UPDI headers for preprogramming the onboard ATTINY404 MCU. They are used for debugging purposes only!
