Slider Potentiometer - Getting Started
Arduino library
Slider-Potentiometer-with-easyC Arduino Library
Soldered-Slider-Potentiometer-with-easyC-Arduino-Library
First time Arduino user? For a detailed tutorial on getting started with Arduino, see this section of our docs:
Getting started with Arduino
Note: The library is only required for the Qwiic version of the product.
Connections
| Qwiic | Qwiic |
If you prefer, you can use I2C pins to manually connect:
| IO21 (Default SDA pin) | SDA |
| IO22 (Default SCL pin) | SCL |
| VCC | VCC |
| GND | GND |
The IO21 and IO22 pins may differ depending on the board you are using, so make sure to validate the information before you start working!
