Apds-9960 – Getting started
Arduino library
APDS-9960 Color and Gesture Sensor breakout Arduino library
APDS-9960 Arduino library by Soldered
Are you a first-time Arduino user? For a detailed tutorial on getting started with Arduino, refer to this section of our docs:
Getting started with Arduino
A comprehensive tutorial on how to set up and upload code to an Arduino board for the first time, from scratch!
Connections
QwiicQwiic
If you prefer, you can manually connect using I2C pins:
IO21 (Default SDA pin)SDA
IO22 (Default SCL pin)SCL
VCCVCC
GNDGND
IO25 (any digital pin works)INT
The VLED pin is used for power to the IR LED if the JP3 jumper is open.
3V3VLED
