Bmp180 - Getting started
Arduino library
To install the Arduino library, download it from the GitHub repository:
Pressure & temperature sensor BMP180 breakout Arduino library
BMP180 Arduino library by Soldered
Getting started with Arduino
Connections
| Qwiic | Qwiic |
If you prefer, you can use I2C pins to manually connect:
| IO21 (Default SDA pin) | SDA |
| IO22 (Default SCL pin) | SCL |
| VCC | VCC |
| GND | GND |
