BMP388 Pressure & Temperature Sensor - Forced measurement
In this example we will take forced measurements with the BMP388 sensor. Unlike a continous measuremnt, a forced measurements wakes up the sensor, takes a measurement and then puts it back to sleep.
Setting up
Setting up is done in the same way as it was done for taking a continous measurement:
// Include Soldered BMP388 library.
#include <BMP388-SOLDERED.h>
// Create BMP388 sensor object.
Soldered_BMP388 bmp388;
// Initialize serial communication at 115200 bauds.
// Initialize sensor (check for sensor). Notify if init failed.
// Also, this will set BMP388 sensor into sleep mode.
if (!bmp388.begin())
// Print error message.
Serial.println("Sensor not found! Check your wiring!");
// Stop the code!
while (1)
// Delay for ESP8266.
delay(10);
// Set current pressure at sea level to get accurate altitude readings.
bmp388.setSeaLevelPressure(1025.0);
Taking measurements
When taking a forced measurement, we first ask the sensor for data and then we print it out to the Serial monitor:
// Variables for storing measurement data.
float temperature, pressure, altitude;
// Make a request for new measurement!
bmp388.startForcedConversion();
// Check if the measurement is complete.
if (bmp388.getMeasurements(temperature, pressure, altitude))
// If the measurement is complete, print results.
Serial.print(temperature);
Serial.print(F("*C "));
Serial.print(pressure);
Serial.print(F("hPa "));
Serial.print(altitude);
Serial.println(F("m"));
// Wait a little bit.
delay(1000);
Requests a new forced measurement from the sensor
Returns value: None
Serial monitor readings
Serial monitor
See the full example below:
// Stop the code!
while (1)
delay(10);
delay(1000);
