Quick start guide
To get started with Arduino on Inkplate 2, a few simple steps need to be completed to install the required software.
1. Install Arduino IDE
If you haven’t installed it yet, download and install the Arduino IDE from the official website.
Arduino IDE 2.0 or newer is required for Inkplate 2.
Install Arduino IDE
Arduino IDE 2.0
2. Install Inkplate boards definition
Copy the following URL:
https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/master/package_Dasduino_Boards_index.json
And add it to the Additional boards manager URLs in Arduino settings:
Add Inkplate to Arduino boards Manager
Adding the Inkplate boards link to Arduino IDE
Now, you can open the Boards Manager, search for Inkplate Boards, and install the Inkplate Boards board definitions.
Click Install here:
Adding Inkplate boards to Arduino IDE
3. Install Inkplate library
In the Arduino Library Manager, search for the Inkplate Motion library and click Install:
Installing Inkplate library
It's also possible to install the library manually by downloading it from the GitHub repository.
4. Install CH340 driver
Mac and Linux users can skip this step because the CH340 driver is already installed.
The CH340 is an onboard chip that enables serial communication over USB. If the driver is not installed, download it from this link. Start the installation and follow the instructions:
Install CH340 Driver
Installing the CH340 Driver on Windows
Done!
Inkplate 2 setup is complete. Now, try out some examples from the Arduino library—upload them and see the results for yourself! See the next page in the documentation for details on how to upload code:
Uploading code
To upload your own sketch or an Arduino example to Inkplate 2, follow this brief guide.
1. Connect Inkplate via USB and power it on
Use the provided USB-C cable to connect Inkplate 2 to your computer. The board is powered on!
Inkplate 2 onboard USB-C connector
2. Create a sketch
For the needs of this documentation, we will be using a premade example. Go to File->Examples->InkplateLibrary->Inkplate2->Basic->Inkplate2_Hello_World
Selecting a basic example for Inkplate 2
3. Upload the code
Before uploading the code, select the correct board definition. The table below should help you out:
Board DefinitionBoard Description
Soldered Inkplate2The newer and more stylish version of the product, and the PCB is purple.
Click Upload in the Arduino IDE.
Once the process completes, Inkplate will restart automatically and run the newly uploaded code. Arduino's upload log should read:
Leaving...
Hard resetting via RTS pin...
Troubleshooting
Having problems with uploading your first code? Check out our troubleshooting page:
