Inkplate 6FLICK – Free GPIO pins
Inkplate 6FLICK's onboard ESP32 WROVER-E has some pins reserved for internal use (for example, the connection to the e-paper display) and cannot be used for end-user applications. This page contains a list of the available GPIO pins that can be used for external applications.
If you don't need pin details and are just interested in the pins, here are the Inkplate 6FLICK pins that are not connected to any external component: ESP32: IO36, IO39, GPIO EXPANDER 1: P1-7, P1-7, GPIO EXPANDER 2: P0-0 to P1-7
Inkplate 6FLICK free pins
Free pin table
PINCONNECTED TOFUNCTION
TXDCH340UART transmit pin
RXDCH340UART receive pin
IO12SDCARDADC2_CH5, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3
IO13SDCARDADC2_CH4, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER
IO14SDCARDADC2_CH6, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2
IO15JP3 Check jumper detailsADC2_CH3, TOUCH3, MTDO, HSPICS0, RTC_GPIO13, HS2_CMD, SD_CMD, EMAC_RXD3
IO34JP6 Check jumper detailsADC1_CH6, RTC_GPIO4
IO35V_BATADC1_CH7, RTC_GPIO5
IO36FREEADC1_CH0, RTC_GPIO0
IO39FREEADC1_CH3, RTC_GPIO3
P1-1JP7 Check jumper detailsSD_DATA1, EMAC_TX_ER
P1-5JP8 Check jumper detailsSD_DATA1, EMAC_TX_ER
P1-6FREESD_DATA1, EMAC_TX_ER
P1-7FREESD_DATA1, EMAC_TX_ER
GPIO Expander 2: P0-0 - P1-7FREESD_DATA1, EMAC_TX_ER
