Microsd Reader - Initializing the SD Card (example)
This page contains an example of initializing the SD card.
Connecting to the board
Defining the CS pin
At the beginning of the example file, we define the pin to which the Chip Select (CS) is connected by changing the SD_CS_PIN variable. In this tutorial, we picked GPIO5:
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else // SDCARD_SS_PIN
const uint8_t SD_CS_PIN = 5; //SET THIS PIN
#endif // SDCARD_SS_PIN
Setup() function
In the setup function, we initialize a Serial connection to the PC; once it is established, we print out the current library version.
//Initialize serial communication
// Wait for USB Serial
while (!Serial)
SysCall::yield();
Loop() function
In the loop function, we wait for user input and then attempt to initialize an SPI connection with the card reader. If it fails, a message is printed via the Serial monitor along with some troubleshooting ideas:
// Read any existing Serial data.
clearSerialInput();
// F stores strings in flash to save RAM
cout << F("\ntype any character to start\n");
while (!Serial.available())
SysCall::yield();
uint32_t t = millis();
if (!sd.cardBegin(SD_CONFIG))
cout << F(
"\nSD initialization failed.\n"
"Do not reformat the card!\n"
"Is the card correctly inserted?\n"
"Is there a wiring/soldering problem?\n");
if (isSpi(SD_CONFIG))
cout << F(
"Is SD_CS_PIN set to the correct value?\n"
"Does another SPI device need to be disabled?\n");
return;
cout << F("SD Card successfully initialized!") << endl;
return;
Initialization error output on serial monitor
Initialization success output on serial monitor
sd.cardBegin(SdSpiConfig spiConfig)
Initializes the SD card in SPI mode
Returns value: Boolean value, true for success and false for failure
| Type | Name | Description |
SdSpiConfig (object) | spiConfig | An object of the current SPI configuration, including the CS pin |
Below you can find the full example:
* This program attempts to initialize an SD card
#include "SdFat.h"
#include "sdios.h"
Set DISABLE_CS_PIN to disable a second SPI device.
For example, with the Ethernet shield, set DISABLE_CS_PIN
to 10 to disable the Ethernet controller.
const int8_t DISABLE_CS_PIN = -1;
Change the value of SD_CS_PIN if you are using SPI
and your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SD_SCK_MHZ(16))
#else // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(16))
#endif // HAS_SDIO_CLASS
//Create an instance of the SD card
SdFs sd;
static ArduinoOutStream cout(Serial);
void clearSerialInput()
uint32_t m = micros();
do
if (Serial.read() >= 0)
m = micros();
} while (micros() - m < 10000);
clearSerialInput();
SysCall::yield();
cout << F(
cout << F(
return;
return;
