Pir Sensor - Getting started
Arduino library
To install the Arduino library for the Qwiic version, you can download it from the GitHub repository:
PIR movement sensor with easyC Arduino library
PIR sensor Qwiic Arduino library by Soldered
Getting started with Arduino
Connections
Standard version
VCCVCC
IO4DOUT
IO2SOUT
GNDGND
Qwiic version
QwiicQwiic
UPDI stands for Unified Program and Debug Interface. It is used to program and debug Atmel devices. The Atmel chip on this board is used solely for easyC I2C communication. DO NOT try to use this for sensor communication!
