Inkplate 5v2 – Free GPIO pins
Inkplate 5v2's onboard ESP32 WROVER-E has some pins reserved for internal use (for example, the connection to the e-paper display) and cannot be used for end-user applications. This page contains a list of the available GPIO pins that can be used for external applications.
If you don't need pin details and are just interested in the pins, here are the Inkplate 5v2 pins that are not connected to any external component: P1-3, P1-4, P1-5, P1-6, P1-7. These are all on the GPIO expander peripheral.
Inkplate 5v2 free pins
Free pin table
PINCONNECTED TOFUNCTION
IO12SDCARDADC, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3
IO13SDCARDADC, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER
IO14SDCARDDC, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2
IO15JP3 Check jumper detailsADC, TOUCH3, MTDO, HSPICSO, RTC_GPIO13, HS2_CMD, SD_CMD, EMAC_RXD3
IO34JP6 Check jumper detailsADC, RTC_GPIO4
IO35BATTERYADC, RTC_GPIO4
IO36WAKEUP BUTTONADC, RTC_GPIO0
IO39JP2 Check jumper detailsADC, RTC_GPIO0
P1-1JP8 Check jumper detailsI/O
P1-2JP7 Check jumper detailsI/O
P1-3FREEI/O
P1-4FREEI/O
P1-5FREEI/O
P1-6FREEI/O
P1-7FREEI/O
