Inkplate 5V2 – Hardware files
The hardware repositories for Inkplate 5V2 hardware files can be found at the following links:
Soldered Inkplate 5V2 hardware design
Hardware design, BOM, gerbers, and 3D files for Soldered Inkplate 5V2, designed by Soldered Electronics
Repository contents
The Inkplate 5V2 hardware repository contains everything you need to understand, modify, or manufacture the board. Below is an overview of the available files:
CAD files
Inkplate 5V2 KiCad project
Schematic
The OUTPUTS folder contains the schematic in .pdf format, exported from KiCad. The schematic is divided into sections based on functionality, making it easy to navigate.
Inkplate 5V2 schematic
Inkplate 5V2 schematic 1/6
BOM (Bill of Materials)
Inkplate 5V2 interactive BOM
IBOM for 10
3D files
Gerber files
  • Drill files (.drl) – Provide drilling coordinates for vias and holes.
