Microsd Reader - Getting started
Acknowledgement
The Soldered microSD Card Breakout Arduino library is based on the popular SdFat library by Bill Greiman. As such, its source code is licensed under the GNU General Public License v3.0 (GPL v3). For more details, see the GPL v3 license.
Arduino library
Soldered SdFat Arduino library
Sd card communication Arduino library by Soldered
Getting started with Arduino
A full, comprehensive tutorial on how to set up and upload code for the first time on an Arduino board, from scratch!
Connections
| IO5 (Default CS pin) | CS |
| IO23 (Default MOSI pin) | MOSI |
| IO19 (Default MISO pin) | MISO |
| IO18 (Default CLK pin) | SCLK |
| GND | GND |
| 3.3V | VCC |
