Simple Rain Sensor - Geting started
Arduino library
Simple rain sensor Arduino library
Simple rain sensor Arduino library by Soldered
First time Arduino user? For a detailed tutorial on how to get started wtih Arduino, see this section of our docs:
Getting started with Arduino
Conections
IO14 (Any ADC pin)A0
IO15 (Any Digital pin)D0
VCC5V
GNDGND
Digital version can use any digital input pin while analog can use any analog pin input, Check Pinout drawing for your specific board
Connections (Qwiic)
Below is an example Qwiic (I2C) connection diagram for Dasduino CONNECTPLUS. These pins will be used in the examples throughout this documentation. To change breakout board's address, check the Address selection.
QwiicQwiic
Qwiic versions also contain UPDI headers for preprogramming the onboard ATTINY404 MCU, they are used for debugging purposes only!
