Inkplate 5V2 – HTTPS certificate
Now that Inkplate is connected to the internet, you will likely want to securely receive data from a website. This page contains an example of how to implement an HTTPS certificate for your connection.
HTTPS example
This example shows how to download a .bmp file from the web securely by providing a certificate for the website that will be validated upon connection. Using applyHttpsCertificate() you can store the certificate for your connection:
Inkplate inkplate;
const char* certificate = ""; // Insert your certificate
void setup(){
inkplate.applyHttpsCertificate(certificate);
inkplate.applyHttpsCertificate()
Applies a certificate that will be checked when communicating with a website.
Returns type: void
const char*certificateThe certificate in a string format.
Check out all the above-mentioned functions in this example:
Inkplate5V2_HTTPS_With_Certificate.ino
This example shows how you can download a .bmp file (picture) from the web securely by providing a certificate for the website that will be validated upon connection and display that image on the e-paper display.
