Inkplate 6 – Display modes
As mentioned on the previous page, Inkplate 6 has two different display modes: black and white (1-bit) mode and grayscale (3-bit) mode. This page contains more information on both.
Black and white mode
1-bit, or black and white mode, is the simpler and faster display mode. In this mode, pixels are either black or white. You can use the shorthand defines BLACK and WHITE when selecting colors. For example, to draw and display a single black pixel and a single white pixel:
#include "Inkplate.h"
inkplate.begin();
// Clear the display
inkplate.clearDisplay();
inkplate.display();
// Draw a black pixel at x=100, y=100
inkplate.drawPixel(100,100,BLACK);
// Draw a white pixel at x=200, y=200
inkplate.drawPixel(200,200,WHITE);
inkplate.display(); // Show on the display
Grayscale mode
3-bit, or grayscale mode, allows you to draw in eight different levels of brightness, not just black and white. See below for an approximate visualization of black levels as they correspond to their numerical value in the code:
Let's draw a couple of pixels with different brightness levels:
inkplate.begin();
inkplate.display();
// Draw a pixel with brightness level 0 at x=100, y=100
inkplate.drawPixel(100,100,0);
// Draw a pixel with brightness level 7 at x=200, y=200
inkplate.drawPixel(200,200,7);
// Draw a pixel with brightness level 3 at x=200, y=250
inkplate.drawPixel(200,250,3);
// Draw a pixel with brightness level 2 at x=250, y=200
inkplate.drawPixel(250,200,2);
Inkplate6_Black_And_White.ino
Full example using black and white display mode on Inkplate 6.
Inkplate6_Grayscale.ino
Full example using grayscale display mode on Inkplate 6.
