Inkplate 6 – Drawing graphics
Inkplate 6 allows you to draw graphics on a 800 x 600px canvas.
Adafruit GFX Library
The core graphics library for Inkplate library, created by Adafruit.
Drawing Geometric Shapes
Below is an example demonstrating the functions used for drawing graphics on the Inkplate 6:
BLACK or WHITE. In grayscale mode, use values from 0 to 7. Refer to the display modes page for more details.#include "Inkplate.h"
Inkplate inkplate(INKPLATE_3BIT);
inkplate.begin();
inkplate.clearDisplay();
inkplate.display();
// Draw a pixel
inkplate.drawPixel(100, 50, 0);
// Draw a line
inkplate.drawLine(0, 0, 1023, 757, 1);
// Draw a rectangle
inkplate.drawRect(100, 100, 200, 200, 2);
// Draw a filled rectangle
inkplate.fillRect(300, 100, 200, 300, 3);
// Draw a circle
inkplate.drawCircle(512, 100, 75, 4);
// Draw a filled circle
inkplate.fillCircle(512, 100, 75, 5);
// Draw a rounded rectangle
inkplate.drawRoundRect(310, 300, 400, 300, 10, 4);
// Draw a filled rounded rectangle
inkplate.fillRoundRect(310, 300, 400, 300, 10, 3);
// Draw a triangle
inkplate.drawTriangle(300, 500, 700, 500, 512, 200, 2);
// Draw a filled triangle
inkplate.fillTriangle(350, 467, 650, 467, 512, 250, 1);
// Update the display to render the drawings
inkplate.display();
Below are the detailed references for these functions:
inkplate.drawPixel()
Draws a single pixel on the display at the specified coordinates.
Returns value: none
| Type | Name | Description |
int | x | The x-coordinate of the pixel. |
int | y | The y-coordinate of the pixel. |
uint8_t | color | The color of the pixel. |
inkplate.drawLine()
Draws a straight line between two points on the display.
Returns value: none
int | x0 | The x-coordinate of the starting point. |
int | y0 | The y-coordinate of the starting point. |
int | x1 | The x-coordinate of the ending point. |
int | y1 | The y-coordinate of the ending point. |
uint8_t | color | The color of the line. |
inkplate.drawRect()
Draws a rectangle outline on the display.
Returns value: none
int | x | The x-coordinate of the top-left corner. |
int | y | The y-coordinate of the top-left corner. |
int | width | The width of the rectangle. |
int | height | The height of the rectangle. |
uint8_t | color | The color of the rectangle outline. |
inkplate.fillRect()
Draws a filled rectangle on the display.
Returns value: none
uint8_t | color | The fill color. |
inkplate.drawCircle()
Draws a circle outline on the display.
Returns value: none
int | x | The x-coordinate of the circle center. |
int | y | The y-coordinate of the circle center. |
int | radius | The radius of the circle. |
uint8_t | color | The color of the circle outline. |
inkplate.fillCircle()
Draws a filled circle on the display.
Returns value: none
inkplate.drawRoundRect()
Draws a rounded rectangle outline on the display.
Returns value: none
int | radius | The radius of the rounded corners. |
inkplate.fillRoundRect()
Draws a filled rounded rectangle on the display.
Returns value: none
inkplate.drawTriangle()
Draws a triangle outline on the display.
Returns value: none
int | x0 | The x-coordinate of the first vertex. |
int | y0 | The y-coordinate of the first vertex. |
int | x1 | The x-coordinate of the second vertex. |
int | y1 | The y-coordinate of the second vertex. |
int | x2 | The x-coordinate of the third vertex. |
int | y2 | The y-coordinate of the third vertex. |
uint8_t | color | The color of the triangle outline. |
inkplate.fillTriangle()
Draws a filled triangle on the display.
Returns value: none
Inkplate6_Black_And_White.ino
Full example using a black-and-white display mode on Inkplate 6.
Inkplate6_Grayscale.ino
Full example using grayscale display mode on Inkplate 6.
