Inkplate 6 – HTTPS certificate
Now that Inkplate is connected to the internet, you will likely want to securely receive data from a website. This page provides an example of how to implement an HTTPS certificate for your connection.
HTTPS example
This example shows how to securely download a .bmp file from the web by providing a certificate for the website that will be validated upon connection. Using applyHttpsCertificate(), you can store the certificate for your connection:
Inkplate inkplate;
const char* certificate = ""; // Insert your certificate
void setup(){
inkplate.applyHttpsCertificate(certificate);
inkplate.applyHttpsCertificate()
Applies a certificate that will be checked when communicating with a website.
Returns type: void
| Type | Name | Description |
const char* | certificate | The certificate in a string format. |
Check out all the functions mentioned above in this example:
Inkplate6_HTTPS_With_Certificate.ino
This example shows how you can securely download a .bmp file (image) from the web by providing a certificate for the website that will be validated upon connection and display that image on the e-paper display.
