Inkplate 6COLOR – Hardware files
The hardware repositories for Inkplate 6COLOR hardware files can be found on these links:
Soldered Inkplate 6COLOR hardware design
Hardware design, BOM, gerbers and 3D files for Soldered Inkplate 6COLOR, designed by Soldered Electronics
Repository contents
The Inkplate 6COLOR hardware repository contains everything you need to understand, modify, or manufacture the board. Below is an overview of the available files.
CAD files
Schematic
The OUTPUTS folder contains the schematic in .pdf format, exported from KiCad. The schematic is divided into sections based on functionality, making it easy to navigate.
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
.drl) – Provide drilling coordinates for vias and holes. - Board outline (
