Getting started
Arduino library​
To install the Arduino library, you can use the Arduino Library Manager or download it directly from GitHub:
DE2120 2D Barcode Scanner Arduino Library
DE2120 Arduino library by Soldered
Are you a first-time Arduino user? For a detailed tutorial on getting started with Arduino, refer to this section of our docs:
Getting started with Arduino
A comprehensive tutorial on how to set up and upload code to an Arduino board for the first time, from scratch!
Before you begin – set the scanner to TTL mode​
The DE2120 scanner ships from the factory configured for USB mode. Before it will communicate over UART with your microcontroller, you must switch it to TTL/RS232 mode by scanning the POR232 configuration barcode from the DYScan settings manual.
You only need to do this once — the setting is stored in the scanner's non-volatile memory.
Connections​
The DE2120 scanner communicates via UART (TTL serial). Connect the scanner's TX to the microcontroller's RX pin, and the scanner's RX to the microcontroller's TX pin.
The examples in this library use UART2 on the NULA Mini (ESP32):
NULA MiniDE2120 Breakout Board
IO4 (UART2 RX)TX
IO5 (UART2 TX)RX
3V3VCC
GNDGND
You can also use SoftwareSerial on any two GPIO pins if UART2 is unavailable. See the SoftwareScan example in the library for details. Note that SoftwareSerial is less reliable at higher baud rates.
