How it works
The DE2120 is a compact embedded barcode scan engine manufactured by DYScan. Unlike laser-based scanners that sweep a single line across a barcode, the DE2120 uses a CMOS image sensor to capture a full 640×480 pixel frame and applies onboard image processing and decoding algorithms — enabling it to read both 1D and 2D barcodes from a single snapshot.
DE2120 barcode scanner on breakout board
Datasheet​
How scanning works​
When a scan is triggered, the DE2120 illuminates the target with its 5600 K white LEDs, captures a frame with the CMOS sensor, and passes the image to an onboard 32-bit decoder CPU. The decoder identifies the barcode symbology present in the image, decodes the data, and outputs the result as an ASCII string over the UART (TTL serial) interface, terminated by a carriage return (\r).
The host microcontroller reads this string using the Arduino library's readBarcode() function and can then process or display it.
UART communication​
The module communicates over TTL serial at a default baud rate of 9600 bps. It ships from the factory configured at 115200 bps, but the library automatically negotiates the baud rate down to 9600 bps on first connection.
The communication protocol uses ASCII commands in the following format:
^_^COMMAND<ARG>.
The module responds with an ACK byte (0x06) on success or a NACK byte (0x15) on failure. Barcode scan results are sent as plain ASCII strings terminated with a carriage return.
Scanning modes​
The DE2120 supports three operating modes:
ModeDescription
Manual (Trigger)Scans only when a scan command is sent via software or the hardware TRIG pin is pulled low. Default mode.
ContinuousScans repeatedly without any trigger. Configurable repeat interval for duplicate codes (output once, no interval, 0.5 s, or 1 s).
Motion SenseActivates scanning automatically when motion is detected in front of the sensor. Sensitivity is configurable.
Supported barcode symbologies​
1D Barcodes​
SymbologyNotes
UPC-AStandard retail
UPC-ECompact retail
EAN-8Short European Article Number
EAN-13Standard European Article Number
Code 128High-density alphanumeric
GS1-128Code 128 with GS1 Application Identifiers
Code 39Alphanumeric, widely used in industry
Code 93Compact variant of Code 39
Code 11Telecommunications
Interleaved 2 of 5Numeric, used in shipping
Matrix 2 of 5Numeric
Industrial 2 of 5Numeric
Standard 2 of 5Numeric
Codabar (NW-7)Medical, logistics
MSI PlesseyRetail shelf labels
GS1 Databar (RSS)Small item identification
China PostChinese postal code
2D Barcodes​
SymbologyNotes
QR CodeWidely used 2D matrix code
Data MatrixCompact 2D matrix, industrial use
PDF417Stacked linear barcode, ID documents
Micro PDF417Compact variant of PDF417
Aztec2D matrix, transport tickets
Illumination and aiming​
The DE2120 has two independent light sources controlled via software:
  • White illumination LEDs (5600 K): Flood the target with visible light to ensure the CMOS sensor captures a clear image, even in low-light environments. Enabled by default.
  • Red aiming reticle LED (625 nm): Projects a visible red line to help the user aim at the barcode. Enabled by default.
Both can be independently toggled using scanner.lightOn() / scanner.lightOff() and scanner.reticleOn() / scanner.reticleOff().
Depth of field​
Reading distance varies with barcode size and print quality. The table below shows typical ranges
Depth of field
DE2120 Depth of field
