Deep Sleep
Using deep sleep on Inkplate 2 helps you get the most out of your battery. Since e-Paper doesn't need any power to retain the displayed image, Inkplate 2 can consume little or no current in deep sleep mode, so a sketch can run for months on a single battery.
When your ESP32 wakes up from deep sleep, it performs a reset and runs main.py again. That means your main script is executed on every wake-up.
Make sure you’ve uploaded a main.py file to the ESP32. Put the code you want to run after each wake-up inside it.
Simple deep sleep​
Basic example of using deep sleep on ESP32 and printing current RTC time.
The RTC can drift a little each day, so it's best to resync with NTP once a day to keep the time accurate.
from inkplate2 import Inkplate
import machine
inkplate = Inkplate()
inkplate.begin()
inkplate.clear_display()
# Check for reset reason and print message accordingly
if machine.reset_cause() == machine.DEEPSLEEP_RESET:
inkplate.println("Woke up from sleep")
else:
inkplate.println("Cold boot / soft reset")
# Get UTC time
utc_time = time.localtime()
# Convert UTC -> local time (e.g., UTC+2)
# Offset in seconds (hours * 3600)
timezone_offset = (2 * 3600)
# Apply timezone offset and print time
local_time = time.localtime(time.mktime(utc_time) + timezone_offset)
year, month, mday, hour, minute, second, *_ = local_time
inkplate.print(f"{year}-{month:02d}-{mday:02d} {hour:02d}:{minute:02d}:{second:02d}")
inkplate.display()
# Important delay before going to sleep when writing scripts
# Wait 10 seconds so you can 'catch' it awake to upload new code later on
time.sleep(10)
# Deep sleep for 10 seconds (10000 milliseconds)
machine.deepsleep(10000)
Get the reset cause.
Returns type: machine.CONSTANT
See constants for possible return values.
machine.deepsleep()
This function puts the ESP32 in deep sleep mode for a predetermined number of seconds
intsleep_time_msDeep sleep duration in milliseconds
Full example​
deep_sleep.py
Enter deep sleep and report the wake reason on the next boot.
