Partial Updates
Instead of inkplate.update(), you can use inkplate.partialUpdate() for a faster display refresh. This prevents full-screen flickering, updating only the pixels that have changed in the frame buffer.
Partial Update
Partial updates in black-and-white (1-bit) mode offer the fastest e-Paper update available on Inkplate.
It is recommended to perform a full update after a certain number of partial updates to maintain the lifespan and image quality of the e-Paper display. Around 50 partial updates should still look good, depending on the content being displayed. Use inkplate.setFullUpdateTreshold() to automate this process.
Partial updates are also supported in grayscale (3-bit) mode, but they are significantly faster and more effective in black-and-white mode. In grayscale mode, their primary benefit is reducing full-screen flickering.
#include "Inkplate.h"
void setup(){
inkplate.begin();
inkplate.setTextSize(3);
inkplate.setTextColor(BLACK);
inkplate.setFullUpdateThreshold(40);
void loop(){
int x = -500; // Start from the left of the screen border
while (x < 1024)
inkplate.clearDisplay();
inkplate.setCursor(x, 300); // Set cursor position
inkplate.print("Partial updates!"); // Print scrolling text
inkplate.partialUpdate(true); // Perform a partial update
x += 15; // Move 15 pixels to the right
inkplate.display(); // Perform a full update
delay(1000); // Pause before next update
Performs a partial (fast) update on Inkplate, refreshing only changed pixels to prevent full-screen flickering.
Returns value: None
uint8_t_leaveOnOptional. If set to 1, the e-Paper power supply remains on after the update. This speeds up consecutive partial updates but requires a full refresh afterward to prevent prolonged power draw.
Sets the number of partial updates after which a full update is automatically performed.
Returns value: None
uint16_t_numberOfPartialUpdatesThe number of partial updates before a full update (inkplate.display()) is triggered automatically.
Full Examples
Inkplate5V2_Partial_Update.ino
Example demonstrating the use of partialUpdate for fast display refreshes on Inkplate 5V2.
